ARP studs install question
Old Feb 22, 2024 | 01:53 PM
keninnc's Avatar
I will admit I was looking at ARP studs since all the cool kids were doing them.
I just ordered the kit with bolts.
Realistically my D2 is a trail truck that gets about 2,000 miles a year. No way I will see the next 20,000 miles on this truck.
Old Feb 22, 2024 | 04:04 PM
Extinct's Avatar
Originally Posted by RoverMasterTech
I would not go with studs. They will not benefit you at all. I have seen a much higher instant failure rate from studs than from aftermarket TTY bolts.
This
Old Feb 22, 2024 | 04:11 PM
PickleRick's Avatar
The debate of head studs vs tty bolts is nearly as heated as your choice of oil, politics or religion.
But if you have instant failure on either method of holding down your head gasket your installer or your machine shop screwed up.
Old Feb 23, 2024 | 12:17 AM
Richard Gallant's Avatar
I went with studs, they are just simpler, TTY are a little more finicky but fine as long as you do it correctly
Old Feb 23, 2024 | 10:16 AM
sqlbullet's Avatar
Originally Posted by PickleRick
... oil, politics or religion.
Pumpkin Seed oil
Surprise Party
Jedi
Got a problem with that? :-)
Old Feb 23, 2024 | 11:00 AM
Best4x4's Avatar
I've used both & if done correctly they both work fine.
Old Feb 23, 2024 | 02:47 PM
Harvlr's Avatar
When using bolts I feel that it’s important to mark the bolts after doing the first torque with the torque wrench. The odds of slipping off on one or two of the bolts is high. If you didn’t mark them you won’t know where you’re at. I also put a piece of plywood on the windscreen to prevent me slipping off and smashing it.
Old Feb 23, 2024 | 03:34 PM
mln01's Avatar
Agree. Use a Sharpie to mark the TTY bolt heads to keep track of how many degrees they're turned.
Old Feb 23, 2024 | 05:22 PM
Extinct's Avatar
I use a paint pen and Mark not only the bolt heads but also the socket and extensions that I use. It's not so important that you are precisely 90° on the first cycle but you want to be dead nuts at 180° when you finish
Old Feb 24, 2024 | 07:17 AM
PickleRick's Avatar
Some of my techs struggle with the hokey pokey.
