ARP studs pulled my threads
This guy over on the LRO forums had that issue with the bolts. Ended up using Timeserts and it seems to have worked out alright for him.
https://www.landroversonly.com/threa...exceed.159058/
https://www.landroversonly.com/threa...before.159062/
Going from memory I think you did it wrong (if your pic is an indiction) according to the ARP instructions, I believe you are just supposed to snug the studs in to the block and then put the heads on and then cleaned bolts/washers, and some grease somewhere in there, and then torque per specs.
Richard Gallant (04-08-2023)
Just used ARP studs on my 95 D1 4.6L. Used an allen and put the studs in till they stopped, Made sure heads were clean where washers sit, used ARP lube, and did 20/50/75. Darn specs list 70/80 so I went in the middle. No issues and I did the job 2 times. First on 3.9L when I thought it was just HG & second time when we slapped in a GEMS 4.6L vs the 3.9L with a cracked block.
Timeserts or Helicoil are stronger than original threads when done properly, my concern woyld be block stress, which cylinder? You may want to hot pressure test after correcting. Honestly with your investment in that block I would send the entire assembly to your machine shop and have them do it.
Alex_M (04-10-2023)
That sucks. Block threads were probably already damaged before you got in there. When I put in my ARP studs, I hand tighten them w/allen wrench until they bottom out, then back off 1/2-3/4 turn. I do not leave them bottomed out, and no lube on the block side of the studs at all. ARP lube for head side of studs as recommended....
agree with above. Your block will be fine with coils, but have a machine shop do them. unless you have a way to tap dead on...and i would suggest a taper tap to start, and then switch to a blind tap. Also, driving in the coils can be a real pain if they bind half way in.....
Anyone have experience with these?
https://www.quantiserv.com/metal-sti...thread-repair/
Blind Full Torque threaded inserts. I like the blind aspect of them seeing as I’m close to water jackets. Wish I had kept my old block to drill through the holes and see how much metal is under the holes.
