ARP Studs vs stock
Old Dec 1, 2014 | 10:59 AM
gbob's Avatar
Default ARP Studs vs stock
Opinions and belly buttons.....everyone has one. I'd like to hear opinions/arguments for both ARP vs stock studs.
My mechanic will do the HG job, but I am leaning toward ARP. My mechanic (a very trusted landy mechanic) has never done an ARP job. Says he'll do whatever I request, but thinks ARP is not necessary. Also, torque spec on ARP? 70? Does that sound right? Bottom line, trying to minimize another HG job down the road. Thoughts?
Old Dec 1, 2014 | 11:04 AM
dusty1's Avatar
I like arp. less equation, but maybe less clamp under expansion
Bolt Engineering - Torque to yield and Torque/Angle Tighten (TTY & TAT) - Mickey's RV8 Site
Old Dec 1, 2014 | 11:06 AM
drowssap's Avatar
follow this and decide for yourself:
2015 ARP Catalog
I believe ARP say 100psi, but think most people stop around 80-85psi
personally i would not put another one together without suds
Old Dec 1, 2014 | 12:29 PM
ZGPhoto's Avatar
If I'm having a shop do it, studs. If I'm doing it, stretch bolts.
Old Dec 1, 2014 | 04:50 PM
coors's Avatar
It's a personal preference. Both fasteners are completely acceptable. I just did studs, installation was a breeze (just follow directions) I torqued them to 70ft/lbs. We'll see how long they hold ( I'm not worried though).
Studs vs TTY bolts is an endless battle that will never end. What happens when you assign five engineers a single problem, you'll end up with five perfectly reasonable answers.
Simply put If you maintain your cooling system you minimize the risk of head gasket failures.
Old Dec 1, 2014 | 09:14 PM
dr. mordo's Avatar
Do some searching over at landroversonly.com - there have been several threads over there about people pulling the threads out of their blocks with the stock bolts. There are also reports of different torques people have tried.
Personally, I'll be using studs and the best head gaskets money can buy when I do it.
Old Dec 2, 2014 | 09:57 AM
Yoops Racing's Avatar
bingo this is why ARP is the best choice
Old Dec 2, 2014 | 10:06 AM
dusty1's Avatar
I checked torque on my factory head bolts before removing.
All over the place and the ps rear 2 bolts were hardly tight.
Coincidentally (or maybe not) that was the area that was weeping. Heads and block were flat and gasket looked as good as new.
Just an experience that I had. Not saying it was the fault of bolt stretch or over stretch, but that would be 1 of a few possible explanations.
Old Dec 2, 2014 | 01:43 PM
coors's Avatar
My experience was a little different from Dusty's. I had leaks at the PS rear and DS rear but all my TTY's were tight, I mean real tight (I wish I would have measured their torque values).
sdhow
Jan 4, 2020 11:02 AM
ls1morethanyou
Feb 8, 2015 02:48 AM
wyrdvans
Jan 9, 2015 09:06 AM
CANAMDiscovery
Apr 22, 2013 08:34 AM
Willie00d2
Feb 25, 2013 02:56 PM
