ARP Studs, what torque to you stop at?
Old May 3, 2018 | 11:16 AM
Roby466's Avatar
Default ARP Studs, what torque to you stop at?
I have my new kit of ARP studs for my head gaskets job (amongst other things)
ARP used to recommend 100 ft-lbs but that was considered way too high. The instructions in my kit say 20, then 50, then 70.
Is that ok? Did you guys pull threads doing that? All my bolts came out as easy as head bolts can come out and the threads are all fine.
What do you think?
I'm doing the cam bearings tonight, then new camshaft in there and then I will start putting the heads back on so I'm still a few days away
Thanks
David
Old May 3, 2018 | 11:23 AM
abran's Avatar
I go 70
Old May 3, 2018 | 12:07 PM
CollieRover's Avatar
Great question! I just got a call from the shop and my heads are nearly done.
Old May 3, 2018 | 04:59 PM
No Doubt's Avatar
I watched the Atlantic British youtube video before I did my ARP studs and they went to 85 ft pounds on the nuts!
I didn't have the guts for that. I *really* didn't want to crack the heads or strip threads in the block.
I went to 81 ft pounds.
Probably 60 ft pounds and up would hold, I bet.
*the best tip in that video above is to use a 3/6" hex wrench with no torque to screw in the studs with loctite prior to installing and torquing the nuts
Old May 4, 2018 | 04:16 AM
Roby466's Avatar
Thanks guys! 70 it will be I suppose. For now I have to wait as I wrecked my cam bearing no.1 and just ordered another set... I'm debating pulling the engine but then it will end up being a full ''while you're in there'' with top hat sleeves and all...
Old May 4, 2018 | 09:27 AM
briancbev's Avatar
After lots of research, I went with 60 ft/lbs. That was three years and thousands of miles ago. If interested, see my thread from Feb 2015.
https://landroverforums.com/forum/di...et-tips-71818/
Old May 4, 2018 | 10:00 AM
Roby466's Avatar
just read it, thanks.
Interesting debate... crazy they used to recommend up to 100 ft-lbs an now 70
Old May 4, 2018 | 02:19 PM
The while you're In there sounds like more fun, but I am a masochist i think.
Old May 4, 2018 | 08:07 PM
Roby466's Avatar
I know, I'm tempted in so many ways but with my wife being away and the kids, I only have a couple hours a night to work if that. Pulling the motor would extend the project by a month or so and summer is comin quick!! I want the D2 going
Old Mar 8, 2021 | 09:54 PM
Wargoob's Avatar
4th Gear
Default Im curious how your heads are holding up?
I just put my heads back together and torqued to 70 ft pounds and it's leaking antifreeze from the back corner of the head.. should I pull the valve covers and torque it more? Heads were machined flat and block checked out... gaskets are on metal side up.. I followed torque sequence
