ATF fluid
Old May 29, 2009 | 07:51 AM
kenk's Avatar
Default ATF fluid
Quick question, changing my tranny fluid, I fell up a quart and half short(dont ask how). My neighbor had a couple bottles of mercon v that said could be used in vehicles with dex III. O.K. to use 1-1/2 quarts?? I did add a bottle of lucas if that makes a diff. Its a ' 98 disco.
Old May 29, 2009 | 09:11 AM
okdiscoguy's Avatar
I am gonna say no. I don't think Mercron 5 is reverse compatible with Dexron 3. Read the bottle.
Old May 29, 2009 | 04:03 PM
kenk's Avatar
I hope this isn't too lame a question, but how do you tell how if the tranny's full? The dipstick says "check cold, ideling in neutral" So I checked the level 1st thing in the morning, adding fluid a little at a time while its ideling in neutral. I dont know if it was the tranny warming up, but the fluid level jumped from the low mark to 1/2 inch over the high mark. Normal??
Old May 29, 2009 | 04:16 PM
The sudden jump in fluid level is because of the fluid stuck to the sides of the dipstick tube.
Let it sit for a hour or so and then recheck it.
Old May 29, 2009 | 08:41 PM
kenk's Avatar
Thanks guys, in 20/20 hindsight I dont know why I bothered. With 138,xxx I'm just gonna change the filter too. But speaking of such, does just the cross member or the y-pipe too have to come out?
And does anyone happen to know, my rear carpet says 50th anniversary edition. How can I tell if it is so? Dosent look any diffrent than any other disco's I've seen
Thanks again
Old May 30, 2009 | 04:32 AM
Yes the cross member and y-pipe need to come out.
And the 50th anniversery edition just says 50th, nothing else special about it.
Old May 30, 2009 | 11:58 PM
discoxd's Avatar
but it is special... it truly is...
Rolltop
May 5, 2014 09:17 AM
kimsd
Sep 25, 2013 01:02 PM
thehun
Jun 24, 2012 07:02 PM
Backpoints
Nov 5, 2009 03:35 PM
scottagnew101
Aug 7, 2007 08:44 AM
