ATF fluid change
Old Aug 6, 2007 | 05:53 PM
scottagnew101's Avatar
Default ATF fluid change
I have been reading about ATF fluid change and that dropping the pan will get around 6 qts out. I am not sure when the fluid was last changed, i assume it was around 25,000 miles or so. And i assume it was done at the rover dealer. This would mean it was changed with DEX III; what if i just change 6 qrts for a simple "up keep" would it be ok to replace 1/2 with DEX V or synthetic ATF? In other words is having 6 qrts of DEX III and 6 qrts of DEX V or Syn. ok?
And about how long does it take to change the oil, drop the pan, clean and replace? Thanks,
Scott
2000 DII with 93,000 miles
Old Aug 6, 2007 | 07:16 PM
Default RE: ATF fluid change
You don't have to drop the pan, there is a drain bolt and a fill bolt in the pan. You will also only be able to drain a little under 5 qts at best. Make sure after filling it up, start the engine shift drive to reverse and then recheck, adding as necessary.
Mike
Old Aug 6, 2007 | 08:46 PM
thanks for the help mike. But would it be ok to use different types of fluids?
Old Aug 7, 2007 | 08:44 AM
The only other fluids available are the non racing type synthetics which are great, way to expensive when you consider you have to pay for a flush and 12 quarts of fluid.
Why not just change your fluid more frequentily if you are pushing your truck that hard, I drain mine of every 15,000 miles to assure it will hold up.
Mike
Athana
Jun 8, 2019 10:23 AM
Rolltop
May 5, 2014 09:17 AM
collin Barrows
Aug 28, 2011 07:13 AM
treant985
Dec 27, 2010 02:51 PM
kenk
May 30, 2009 11:58 PM
