Attached Battery Backwards, Sparks
I knew I liked you Abran! I had a 164s for awhile, a couple of Milanos and a GTV6. Moved on, but still check CL for them...
Andy2Rover (12-24-2015)
Codes are:
P0705: (reference: Engine anti-theft signal circuit high Serial link open circuit)
P1668: (reference: (14, 23) * Gear position switch, incorrect outputs Maintains current gear in low range, limp home mode in high range. Shift pressure to maximum, harsh gear shifts/engagement. On On)
When I turn the key to just before ignition, M&S light blink continuously as well as a B with a line through where normally it would show the Gear status, like D for drive, R for reverse: So all the possibilities showing up at once flashing, and the stick won't allow me to shift into anything. Haven't and won't try turning over until I fix this. It's inconveniently parked at a friend's apartment complex though, and has been for a week... Oops.
Headlights come on.
All windows don't work, including two sunroofs.
Radio won't come on.
Air comes on and blows.
Interior lights come on.
Windshield wipers come on but when I turn them on, the truck gets mad at me, it seems, by inexplicably turning on the interior light, dinging the "lights still on with key out" ding, and showing me the green trailer light and red seatbelt light.
Thoughts?
Headlights come on.
Thoughts?
Also, do you think the Alternator fuse being blown could be part of it, and where is it located? I can't find it mentioned in the service manual.
The entire alternator may need replaced; the thin trail of smoke was coming from somewhere in that direction when hell broke loose, but in the couple moments of panic I didn't look exactly at where it was coming from, I just disconnected the cables. The reason for replacing the battery was that it was dying on us. Could be the alternator was causing this. Maybe that would help my codes? Or helpful, but not for fixing the codes?
Looking at things simply the alternator shouldn't stop it starting. If you had a fully charged battery. Alternator circuit just charges things back up. Unless there are LR specific things I'm missing.
What are the symptoms on it not starting? Could be that the computer is not allowing the fuel pump to operate etc. what's it doing, sounding like?
Try hitting the inertia switch. In case that gets triggered with your situation.
I would buckle in for the long haul. If it's stuck somewhere unfortunate, can you tow it to a more helpful place?
za105 (12-26-2015)
Makes sense about the alternator.
Nothing happens when I turn the key to start, lights go off and nothing. Release and back to those flashing lights.
Will check inertia switch next time I'm at the car.
How do I tow it in park? I've been trying to figure that out. Gotta get it home to work on it.
Defo put 12v straight to the starter if you can. Prove to yourself something sensible is happening.
Do you have a multimeter with a beep function? Each fuse I think has a little gap you can stick your probes. The little ones inside. Quickly check which ones are still good. Couple of fuse boards to find.
Sounds like a nightmare. But I would want to start narrowing down the obvious. Until someone says a BCU is broken. Then I would scream with a lack of knowledge.
