Audio output and speaker hum
Old Apr 7, 2024 | 01:14 PM
fowlerjk04's Avatar
Default Audio output and speaker hum
This is a combination of issues, I think. At least a combination of symptoms.
With the 2000 D2, I have an aftermarket head unit (bought that way) and it appears the subwoofer in the rear door is missing. I have audio from the front speakers without any problem. However, the rear speakers only produce the hum we all know that is tied to a ground fault (you know, the one that changes with engine RPM). Sometimes it's there, sometimes it isn't. Regardless of hum, the rear speakers never produce audio output from the head unit.
I have tinkered with all audio settings. No change.
I assume there's a loose connection between the head unit and rear speakers. Sounds like it was never connected at all and the wires are hitting something every now and again that allow that hum to happen.
Where to start tearing this thing apart and troubleshooting? I am very nervous about pulling panels. Brittle plastic scares me. I'd love to pull it all and do a complete rewire with a stock D2 head unit or one that will keep bluetooth/carplay capabilities without looking so out of place in the dash.
Old Apr 8, 2024 | 02:23 PM
fowlerjk04's Avatar
Update: The factory amplifier under my driver's seat looks to be connected OK. This is a high-line system with the HK speakers everywhere. I reseated the amplifier connector just to see if that would have any effect. Everything turned off when I disconnected it and came back when I reseated it, but no difference in speaker audio. Pulled the Kenwood head unit and swapped around the connectors. Front/Rear/SW available in the back and the only two connected were Front, which I assume goes to the amp for distribution to ALL the speakers. Swapping them around had no effect. While I was doing this with the engine off I noticed the rear speakers came alive with static but no audio.
What should I investigate next? I wonder if the amp itself has gone bad? It appears to be powering those rear door speakers but no audio from the head unit.
Old Apr 8, 2024 | 09:46 PM
Saturnine's Avatar
On my pioneer HU, I had to turn on the subs via the audio menu.
Old Jun 8, 2024 | 10:16 AM
fowlerjk04's Avatar
Fixed, just replaced the aftermarket with a stock unit. It’s great! Only problem now…a THUMP from one speaker any time I change radio stations or CD tracks. Speaker or amp problem?
Extinct
Dec 13, 2023 09:08 AM
Pete C
Apr 11, 2021 06:11 AM
04in719
Jul 3, 2017 07:56 PM
Hyakku
Apr 23, 2012 11:39 AM
calebbo
Audio/Visual Electronics
Dec 6, 2010 05:50 PM
