Rear speakers clipping
Old Dec 10, 2023 | 08:25 AM
Extinct's Avatar
Default Rear speakers clipping
Hey guys, put a Android 10" touchscreen in the dash with a Scosche SLC4 line out audio converter and have adjusted to optimize noise but if I turn up the volume medium loud the rear speakers start clipping. I have the fader balanced slightly to the rear based on my height and seat position. Never had this with factory head unit, anyone else run in to this? Wondering if I should replace amp or speakers first (I have both available). Been out of the car audio game a while (worked my way through college as an installer/competitor) and always thought D2 factory systems did not need much help.
Old Dec 10, 2023 | 11:15 AM
mollusc's Avatar
What head unit are you using? Weird that it wouldn't already have line level outputs.
Old Dec 10, 2023 | 06:42 PM
Extinct's Avatar
It is one of the Amazon cheap android Chinese units. Has low level out but only two channels, not four. Using the speaker out in to the Scosche adapter to feed the factory amp currently.
Old Dec 11, 2023 | 08:25 AM
mollusc's Avatar
Oof. That sounds really bad. I run a Cheap Chinese android unit but it has four line-level outputs and four speaker-level from an onboard amp. No real problems with clipping using the Rover amp from the line outputs. Hate to say it, but it may be better to get a different unit instead.
Old Dec 11, 2023 | 12:27 PM
greisinb's Avatar
Well, the amp is really easy to replace so I would start with that, I think it's just one plug, so you might not even need to take the original one out to do a quick A/B test.
Old Dec 13, 2023 | 09:08 AM
ahab's Avatar
I'm not sure how important this is but the Scosche website specifically mentions that it works with Bose, and doesn't list the Land Rover as compatible. Perhaps Alpine simply isn't going to fly.
Pete C
Apr 11, 2021 06:11 AM
parrotheadinalb
May 23, 2014 10:36 PM
ninjaff21
Jun 28, 2013 04:16 PM
VikingDiesel
Oct 25, 2009 09:33 PM
oljohnboy
Sep 23, 2009 11:05 AM
