Audio Whine - rear door tweeters only
Old Aug 31, 2022 | 02:48 PM
Extinct's Avatar
Default Audio Whine - rear door tweeters only
Cross post to the audio section, but it is on my D2.
Recently installed a Chinese made 10" touchscreen, used the Schosche SLC4 (https://www.scosche.com/car-stereo-output-converter)adapter and two pac SNi-1 RCA noise filters (https://catalog.pac-audio.com/catalo...erfacing/sni-1). Thoroughly grounded the head unit caseing/housing to the dash metal structure with a separate ground wire.
I have a very annoying alternator whine (increases volume and frequency with engine speed) in the rear door tweeters only. Anyone ever run in to this and have a fix?
Old Aug 31, 2022 | 03:26 PM
JoshD's Avatar
Do you have anything like this plugged into the cigarette lighter? If so, unplug it and see if the whine goes away.
Old Sep 1, 2022 | 06:07 PM
Extinct's Avatar
I wish it was that easy, yes of course I use one of those but unfortunately unplugging that makes no difference. I guess I will have to start installing choke coils in the system.
RoverPA
15
Nov 9, 2020 03:30 PM
timsvoice
Sep 4, 2020 07:15 PM
Ian Mitchell
Dec 16, 2019 05:33 PM
bcurtman
May 7, 2019 01:11 PM
