Auto transmission help??
I have an issue with my recently purchased '99 Disco II. The mode switch seems to do nothing (the M & S lights do not light up even on startup) and the gear position indicator on the instrument panel LCD doesn't show anything. It drives fine so I wasn't too concerned. Now I found that the transfer case wont shift out of high range. I was trinking it could be a faulty gear position switch.
Would failure to sense the transmission is in neutral cause the solenoid on the transfer case to lock up?
Would it cause the mode switch to become ineffective?
dont go jumping into an xyz switch yet, first of the lights should come on at start-up.
You say the M&S light and the light on the shifter do not light, that is strange as that is the signs that your truck is in limp mode.
Flashing M&S lights and a flashing light on the shifter console, im wondering was it in limp mode so long that the bulbs burned out? or some unplugged something.
Is the : on your instrument cluster flashing?
If you shift the lever into 3,2,&1 does it show on the instument panel or just a D?
