Sponsored by: CARiD
auto transmission
Old Jan 4, 2008 | 04:58 PM
allen's Avatar
7th Gear
Default auto transmission
The auto transmissionof my Disco1 just went dead half way when climbing a hill. The engine starts and run ok but all transmission has gone,the car just dont move at all. It is ZF4hp22 gearbox on a 300tdi engine.
please help!!
Old Jan 4, 2008 | 07:31 PM
Default RE: auto transmission
Are you sure it is the tranny and not a failed diff or axle? Put it in drive, look under the truck at both drive lines, is one of the turning, if so, there is you answer.
Old Jan 4, 2008 | 10:07 PM
allen's Avatar
7th Gear
mike,
I did the check underneath, nothing moving. Could it be the torque converter problem, cause it seem like the tranmission dont receive any power at all.
Old Jan 5, 2008 | 09:18 AM
Well, I was hoping it was a cheep repair like a dif, which is common.
Have you tried shifting the t/case just in case it has popped into neutral, other wise you are off to the tranny shop.
Try not to use a dealer if you can, it will/can cost more then going to a small tranny shop.
Old Jan 8, 2008 | 07:59 AM
allen's Avatar
7th Gear
Mike,
I've sent the car to the workshop. Unfortunately, it is the torque converter. The inner gear of the converter(the fixed to the tranny shaft)is flatten. the mechanic had advise me to get a 2nd hand converter for replacement (50% cheaper). What could possibily cause the problem? is it safe to use the 2nd hand parts?
thanks
Old Jan 8, 2008 | 08:41 AM
Could have been some sort of a flaw in the casting for the gear, it is hard to say.
I would go for a reconditioned or used t/c in a heart beat.
discoxd
Nov 25, 2008 05:28 PM
ios1000
Jan 28, 2008 08:26 AM
master
Freelander
Jan 17, 2008 09:26 AM
master
Jan 9, 2008 08:55 AM
cold_surfer
Mar 19, 2007 01:13 AM
