AUX Light Failure
AUX Light Failure
My disco came with AUX lights from the factory. The system failed last year, so I replaced it with a relay that was wired to the high beam. It worked fine. Then I bought a cruise control switch with a fog light cover on it from this forum. I wired it in using the diagram attached. It worked for 2 weeks and then the whole system stopped working today. Fuses are fine, bulbs are fine, connections are all okay. I even bypassed the switch and still nothing happened. However, with or without the switch in the circuit, the relay still clicks when it's supposed to. Do I need a new relay?
Tried the new relay, and it kind of worked. Let me explain:
When I connected the new relay, the lights came on so I put everything back in its place. Then only one light came on, so I turned the lights off and re-did all the splices and connections. I turned them on again and none of them turned on. Everything had continuity but when I used the multi-meter to test the positive output of the relay (while it was on), there was no voltage.
Any ideas?
Thanks.
Any ideas?
Thanks.
marlymarl
05-28-2011 10:34 PM
angasreid
11-16-2006 11:40 AM
