AUX Light Failure
Old Dec 28, 2015 | 10:16 PM
DiscoCam's Avatar
Default AUX Light Failure
My disco came with AUX lights from the factory. The system failed last year, so I replaced it with a relay that was wired to the high beam. It worked fine. Then I bought a cruise control switch with a fog light cover on it from this forum. I wired it in using the diagram attached. It worked for 2 weeks and then the whole system stopped working today. Fuses are fine, bulbs are fine, connections are all okay. I even bypassed the switch and still nothing happened. However, with or without the switch in the circuit, the relay still clicks when it's supposed to. Do I need a new relay?
Attached Thumbnails AUX Light Failure-dii-driving-lights-kit-modified-relay-latching-switch_zpsa54b0c8e.jpg
Old Dec 29, 2015 | 06:32 AM
drowssap's Avatar
did you try swapping the relay with another
Old Dec 29, 2015 | 12:28 PM
DiscoCam's Avatar
I don't know why I didn't think of that.
I'll try that today.
Old Dec 29, 2015 | 07:20 PM
DiscoCam's Avatar
Tried the new relay, and it kind of worked. Let me explain:
When I connected the new relay, the lights came on so I put everything back in its place. Then only one light came on, so I turned the lights off and re-did all the splices and connections. I turned them on again and none of them turned on. Everything had continuity but when I used the multi-meter to test the positive output of the relay (while it was on), there was no voltage.
Any ideas?
Thanks.
Old Dec 31, 2015 | 07:01 AM
dgi 07's Avatar
Have you checked resistance of the circuit?
If there is to much resistance for the circuit ( it wont trip the relay, and wont work)
Long story short, is your wiring to small.?
Old Jan 3, 2016 | 03:49 PM
DiscoCam's Avatar
As dgi07 said, there was too much resistance on the power feed. I traced it back to the battery cable. What happened was that the bolt that secures the positive wire to the battery cable had gone missing. So I got a new bolt and it works perfectly now. Thanks for all the help guys.
Wayne
Oct 2, 2020 12:10 PM
marlymarl
May 28, 2011 10:34 PM
Disco TN
Nov 21, 2008 08:07 PM
salve7
Sep 12, 2008 03:34 PM
