Average Water Temperature On 96Disco??
Old Sep 29, 2009 | 12:19 PM
josemex's Avatar
Default Average Water Temperature On 96Disco??
I'm having problems with my temperature gaude on my 96 disco and I hooked up a Scanguauge to it via obdII to get accurate readings , any one knows whats the average temperature my disco should run at???[PHP
Old Sep 29, 2009 | 12:32 PM
LRScott's Avatar
I do not have a discovery, but the engine in mine is the same as yours, and will run anywhere between 185 to 210F.
Old Sep 29, 2009 | 01:01 PM
okdiscoguy's Avatar
what are you getting for readings? The above temps are what I get.
Old Sep 29, 2009 | 03:03 PM
josemex's Avatar
I'm getting 195-221 I'm in florida though??? what do you guy's think???
Old Sep 29, 2009 | 03:11 PM
Not knowing the overall condition of your coolant, t/stat and radiator can make a difference but your numbers are OK.
Old Sep 29, 2009 | 04:32 PM
josemex's Avatar
I took off the radiator to clean it and it looked ok , just flush it two weeks ago, fan blows pretty hard and I can listen to the electric fans come on when I turn the ac on.
Old Sep 29, 2009 | 06:13 PM
LRScott's Avatar
Things should be normal then. It is not uncommon for an electrical short to cause the temp gauge to malfunction. Mine does this and it is extremely annoying.
Old Sep 29, 2009 | 06:50 PM
My DI runs at 196 on the road and 200 in traffic, 210 while off roading.
Old Sep 29, 2009 | 08:54 PM
lipadj46's Avatar
In the summer my DII runs 92 C running (196 F) and 100 C (210 F) idling or going slow uphill. Mine ran hot like yours until I did a really thorough coolant flush (engine, radiator and heater).
greenharoguy
Mar 9, 2013 08:03 AM
Vorhees
Oct 10, 2008 07:26 AM
LRScott
Oct 6, 2008 06:42 PM
84crawling
Oct 4, 2008 11:30 AM
mht2007
LR2
Jan 19, 2008 07:21 PM
