The AWD / Full Time 4WD Debate
Old Sep 23, 2010 | 03:12 PM
ShortTom's Avatar
Default The AWD / Full Time 4WD Debate
Ah, brother in laws.
Well we're at it again. My brother in law, while suitably impressed with my recent purchase of my 03 D2, is already bragging up the off roadability of his 1998 AWD Ford Explorer. Of course instead of smiling sweetly and patting him dismissively on the head, I had to get into the debate. He's generally not a jerk about it, but we often go round and round a lot about auto stuff.
He's got a 5.0 Explorer with an automatic AWD system that also has Hi/Lo 4wd.
Claim #1:
That his automatic AWD system is the same as my Rover's full time 4WD. I know this isn't true with typical auto AWD systems b/c they are essentially two wheel drive until severe slippage happens at which point the other axle is given power.
BUT, his AWD has a Borg-Warner transfer case that delivers 35% to the front axle and 65% to the back at all times and varies the ratio as conditions dictate. I know my non-CDL TC permits both shafts to turn at different speeds, again based on slippage, etc (right?). Does he have me? It sounds like they're pretty similar.
Claim #2:
In addition to auto AWD he has Hi/Low, which he says is identical to CDL in that both the front and back axles turn at the same speed delivering equal power to the front and back axles. True? If so, what the heck's so great about CDL if a stinkin' 98 Ford Explorer has it?
He concedes that Rovers are good off roaders, but attributes it to suspension, clearance and torque rather than the TC. Which is basically like saying Rolex's are good but they're only different from a Timex because of a little gold trim and the first three letters of the manufacturer's name.
He's got me on the ropes! Need some ammo if there's any to be had here!
Old Sep 23, 2010 | 03:26 PM
NiteTrain's Avatar
his exploder is IFS and that's exactly what it'll do, explode, if he trys to do any moderate to serious off-roading on rock.
unless Borg-Warner has changed then his transfer case is chain drive, they stretch over time and need replaced. Your transfer case is gear to gear.
Old Sep 23, 2010 | 04:17 PM
I couldn't have said it better. After you learn how to drive your 03, take him for a"Short", don't want to have to tow him too far if it does explode.
There is not a stock Ford that can come close to equaling a Rover.
Old Sep 23, 2010 | 04:24 PM
yloDiscoII's Avatar
HAHA! And take some good videos of for evidence so you can rub it in his face for years to come
Old Sep 23, 2010 | 04:59 PM
tweakrover's Avatar
tell him he's right, but that means he admits that a rover is better, I don't know how strong a ford soccer mom's axles or transfer case are but leaf springs can't touch a coil sprung 4 link.
Old Sep 23, 2010 | 05:02 PM
ShortTom's Avatar
Ah, ok that makes me feel better.
What about the AWD vs FT 4WD? Do our TC's essentially act like an automatic AWD?
And the CDL? Is it true that typical 4wd vehicles lock both shafts together?
Old Sep 23, 2010 | 05:33 PM
ShortTom's Avatar
Ah yes, I think he realizes he's beat there. Yeah, the 4 spring independent suspension allows for full articulation over rough ground and those purely gymnastic profile pics.
Old Sep 23, 2010 | 06:28 PM
Danny Lee 97 Disco's Avatar
The answer is in the dirt to paraphrase Ben Hogan ( His favorite answer when asked the secret of hitting a golf ball). Put a friendly wager on it and go play follow the leader. Invite him to lead the way at first then challenge him to stay with you as you lead.
Have an independent third party hold the money and the video camera. Post it on UTube for all the world to enjoy.
Old Sep 23, 2010 | 08:30 PM
groundassault's Avatar
5th Gear
Rover is the only one that uses a CDL because all transfer cases already split power evenly. That explorer has a rear 8.8" axle that Ford used in F-150s up to 1996. They are known in the Jeep world for being able to be locked on 39's on the stock 31 spline shafts. His Borg Warner is a stout unit but it does have IFS. I wouldn't discount his running gear just because IFS. Remember, most desert runners and Hummer H1s all run IFS
Old Sep 23, 2010 | 09:20 PM
Your t-case send equal power front and rear until you turn a corner or spin a tire, then because of physics it then sends power to the prop shaft of least resistance.
That is what the CDL is for, to prevent that from happening, lock both prop shafts together and they both get equal power no matter what.
Your traction control uses the ABS system to stop a spinning wheel, by stopping that wheel you send the power to the other wheel on that axle, since it is not spinning it must have traction.
Ask him what kind of fluid his transfer case uses, AWD cars use a light fluid in the t-case, such as automatic transmission fluid.
Your t-case sues gear lube, just like a differential, just like the t-case on a cement truck or off road dump truck or any other heavy duty machine that is built for abuse and designed to last forever.
His lo range is for pulling the boat up a steep wet boat launch, not climbing a mountain like yours is.
