Axle Nuts
Old Nov 9, 2007 | 02:55 PM
ajh's Avatar
ajh
Default Axle Nuts
Trying to get the rear axle nut off to change a hub. I've tried a long bar, broke a 1/2 bar, bought compressor and impact wrench, tried hammer-type impact wrench... it's just not budging. The last shop that worked on it did not use a new nut when they pulled it off.
Suggestions?
Old Nov 9, 2007 | 05:33 PM
ajh's Avatar
ajh
Default RE: Axle Nuts
Well, that was welded on. I had to use a grinder to cut apart the hub to get at the nut, then shave the nut down as far as I could then cut a break in it along the lock groove on the axle.
Now I'm up for suggestions on how to prevent this from happening again. It would REALLY suck to break a half-shaft in the field and not be able to replace it.
Would copper anti-seize work?
Old Nov 9, 2007 | 06:49 PM
ajh's Avatar
ajh
OK, I think they overtorqued them when putting them on. Spec is 74ft/lb, I bet they put 400 on it.
As an aside, new rear hub and braking is significantly better. Also no squeal at all from the KVR semi-metallic pads anymore.
dcarr1971
Feb 8, 2013 08:16 AM
cationmoted
Oct 19, 2012 07:39 AM
lajilana
Jul 17, 2006 10:35 AM
Cooper97Disco
Jun 19, 2006 02:47 PM
bmwrovers
Jul 18, 2005 03:13 PM
