Back to Air Springs
Old Sep 19, 2007 | 06:24 PM
humroot's Avatar
Default Back to Air Springs
Last year, my compressor failed on my SLS. After riding around on the bump stops for a day, I decided the cheapest way to get back on the road was by installing a spring conversion kit. I installed the kit and sold the air-springs on eBay. I left the bad compressor in the car to stop the beeping on the SLS. Every once in a while the light would come on, but I was OK with that. Recently I was looking at Discovery stuff on eBay and saw a SLS compressor for $100. What the heck...I bought it. After it came in, I realized I didn't have the air-springs anymore. After another search on eBay I was lucky enough to pick up a pair of brand new Arnott air-springs for around $200 delivered. I finally had everything I needed to convert BACK to air-springs. Let me tell you that removing the coil springs is a heck of a lot harder than installing them. I finally got them installed and fired up the compressor. One side didn't move and one side raised up....and up and up and up. I took it for a little road test to see if that would level it out. Nope....it just got worse. I seriously thought that that one side would explode like a balloon. I shut the truck off and went to examine the compressor. Most of you probably already know what the problem was, but I can assure you that per the RAVE cd, all the plugs were in the right spot. I changed then anyway and after a little hissing and pumping, viola.....I'm level! No air leaks and it works like a champ. Let me tell you, the ride and handling are FAR, FAR SUPERIOR TO COIL SPRINGS! I kid you not, it is a smoother ride and the truck handles so much better it almost feels like a different truck. And now I have the coil springs I can throw on if I need them. I agree that the SLS is an expensive system, and prone to failure, but I don't think I'll convert back to coil springs as long as eBay is around.
Old Sep 19, 2007 | 06:50 PM
Default RE: Back to Air Springs
I keep telling people they shouldn't go to the coil conversion. nice to hear your story.
Old Sep 19, 2007 | 07:54 PM
humroot's Avatar
Thanks, Mike. Actually, you're the one that planted the seed of doubt last time I spoke with you. I'm glad I listened.
BTW - With the spacers for the air springs - after the install, do you need testbook? Thinking about doing it and trying to figure out price. If I need testbook, thats another $130 (local dealer hourly charge).
Do you have any pics of your ride posted anywhere?
Old Sep 19, 2007 | 10:42 PM
95DiscoSE7bullitt's Avatar
No you can slap the spacers under the bags and go. I have the spacersand the arnott bags and I love them easy install only takes about 30 mins.
Old Sep 20, 2007 | 06:57 AM
Ditto, just install the spacers and the height adjusters, adjust the height to the level you want and go.
Old Sep 20, 2007 | 05:52 PM
okdiscoguy's Avatar
any way to add air springs as a conversion on a D1?
rchrd0413
Apr 22, 2014 02:18 PM
Fivespddisco
Member Group And Special Buys
Jul 26, 2012 07:58 PM
texci77
May 26, 2012 09:47 PM
Bellows Fellow
Sep 15, 2010 02:29 PM
rich
Mar 7, 2010 02:52 PM
