Back Door
Old Oct 23, 2007 | 02:59 PM
CPDieker's Avatar
Default Back Door
Ok, I sprayed a can of WD40 back there and it still won't open. Is there a way that I can get to it thru the inside of the vehicle?
Old Oct 23, 2007 | 03:05 PM
jgaeta's Avatar
4th Gear
Default RE: Back Door
i have an 04 discovery II se and i had the same problem, back door wouldn't open. i removed the land rover badge from the handle assembly and sprayed some grease in there on the latch release. tried it a few times, and finally pop, it opened up!. not sure if this is your problem, or the hinges on your door are the problem.
Old Oct 23, 2007 | 03:06 PM
Keep trying.
Old Oct 23, 2007 | 03:10 PM
okdiscoguy's Avatar
spray up into the handle from underneath. Try flipping the handle. On mine, it stuck like you were still holding the handle out and it had not retuned to the right position.
Old Oct 23, 2007 | 03:29 PM
ajh's Avatar
ajh
I popped the inside of the door off, unbolted the handle and just cleaned it properly then put waterproof grease around all the right bits. I also installed a 2nd return spring for the handle to make sure it always goes back into position, it was sticking up sometimes before that.
cobbcj7
Sep 30, 2014 10:38 AM
Externet
Nov 23, 2013 03:28 PM
twaszak
Dec 28, 2012 01:11 AM
Neilzzz0
Apr 14, 2007 01:24 PM
