Back in the game after two years
Old Sep 13, 2015 | 10:59 PM
shady milkman's Avatar
Default Back in the game after two years
Picked up an 04 from a friend of mine, 140k miles that was totaled out due to hitting a deer, mainly cosmetic stuff, hood, grille, headlights, bumper, etc. which has all been fixed already.... The thing has been pampered and only serviced by a great local shop and Land Rover of buckhead.
Anyways I got it from him since he knew I'd take it and knew I'd make it great like my last 04. Well after having it for a day I've got a few problems. First the m and s lights are flashing, probably the battery so no big deal. Second the e brake light illuminates, it'll go off for a second or two but mainly stays on. I worry about this one because when driving it feels as if the brake is slightly on because it takes off like a slug, weird thing is that if it is in reverse it takes off quick as it should. Third, there was water in the front floorboards and a lot of water in the engine bay right above the firewall...where should I look for clogs? And lastly, right beside the abs module, there is a two prong yellow tip wire that is unplugged from somewhere and I can't figure out where it came from. I've done searches but can't find exactly what I need.
Thanks for any advice! Great to be back!
Old Sep 14, 2015 | 12:25 AM
Kenso's Avatar
Check your brake fluid level as far as the brake warning light goes. The seals between the reservoir and master cylinder are a fairly common place for a fluid leak if not the master cylinder itself.
If the M&S lights are flashing that would explain your sluggish takeoff in drive, the transmission goes into a failsafe mode when the M&S lights are flashing and defaults to 3rd gear operation when in drive, so you start off in 3rd gear from a stop..
Old Sep 14, 2015 | 10:57 AM
cappedup's Avatar
Brake light could just be low fluid level. Or ebrake switch.
Wet floor boards is probably blocked AC drains. Bit tricky to find first time looking.
Old Sep 14, 2015 | 03:42 PM
Thanks for the help guys, plan on starting d2 #2 tonight
Old Sep 15, 2015 | 09:33 AM
WNYErikDiscoII's Avatar
Former Sponsor
Post a pic of the unplugged wire. Get a new battery or fully charge the one you have and get the codes cleared. Should delete the M&S lights.
StrangeRover
Feb 27, 2014 11:54 AM
Externet
Nov 23, 2013 03:28 PM
hubot
Apr 17, 2012 09:28 PM
luxury1
Apr 16, 2009 04:04 PM
houstonhelix
Apr 23, 2007 12:07 AM
