Bad ABS?
![Unhappy](https://landroverforums.com/forum/images/icons/icon9.gif)
Got my Amigo reader today and hooked it up. Cleared the HDC light but left the ABS & TC lights on. Not sure if the ABS unit is dead or what (all the fuses are good) but here's what it read:
022:ECU Gnd or Reference Gnd bad
064:Front Right sensor electric fail
065:Rear Left sensor electric fail
066:Front Left sensor electric fail
067:Rear Right sensor electric fail
114:Shuttle Valve Electric Failure
Would the shuttle valve cause al these failures? Hoping for just a bad ground but I doubt it.
Eric
Eric
Well after reading how bad connections and weak batteries can cause problems on these D2's, I decided to disconnect the battery and start checking. The positive cable was a bit loose. I cleaned the battery posts and terminals. Unplugged the ABS unit and cleaned the connections (they weren't clean). Hooked everything back up and cleared the lights with Amigo reader. Went for a 10 mile drive and the lights didn't come back on!
Slammed on the brakes on a dirt road and the ABS functioned normally.
Hopefully, that's all it was. Guess I'll find out when I'm running around tomorrow......
Eric
![Big Grin](https://landroverforums.com/forum/images/smilies/lxvR5hR.png)
![Smile](https://landroverforums.com/forum/images/smilies/H5uKDcM.png)
Eric
