Bad ABS?
Old Aug 27, 2010 | 05:10 PM
SDinDS's Avatar
Unhappy Bad ABS?
Got my Amigo reader today and hooked it up. Cleared the HDC light but left the ABS & TC lights on. Not sure if the ABS unit is dead or what (all the fuses are good) but here's what it read:
022:ECU Gnd or Reference Gnd bad
064:Front Right sensor electric fail
065:Rear Left sensor electric fail
066:Front Left sensor electric fail
067:Rear Right sensor electric fail
114:Shuttle Valve Electric Failure
Would the shuttle valve cause al these failures? Hoping for just a bad ground but I doubt it.
Eric
Old Aug 27, 2010 | 07:32 PM
SDinDS's Avatar
Well after reading how bad connections and weak batteries can cause problems on these D2's, I decided to disconnect the battery and start checking. The positive cable was a bit loose. I cleaned the battery posts and terminals. Unplugged the ABS unit and cleaned the connections (they weren't clean). Hooked everything back up and cleared the lights with Amigo reader. Went for a 10 mile drive and the lights didn't come back on! Slammed on the brakes on a dirt road and the ABS functioned normally. Hopefully, that's all it was. Guess I'll find out when I'm running around tomorrow......
Eric
dparham
Apr 22, 2013 04:03 PM
cobbcj7
Apr 20, 2013 06:45 AM
starcraft1
Nov 13, 2011 08:14 PM
oljohnboy
Sep 14, 2009 03:01 PM
Bene
ROAMING WITH FRIENDS
May 11, 2005 04:33 AM
