Bad Brakes or Bad Caliper?? See Pics
Old Apr 19, 2013 | 09:52 AM
cobbcj7's Avatar
The good and bad pad on each side of this rotor
Attached Thumbnails Bad Brakes or Bad Caliper?? See Pics-img_20130418_144606_084.jpg
Old Apr 20, 2013 | 04:51 AM
Racer X's Avatar
The slide pins on this caliper are toast, the outboard pad isn't even touched.
On a replacement caliper, you don't absolutely need to spend hundreds on a genuine caliper. Over the years I've had good experiences with the A1Cardone line of brake calipers. The Centric stuff works also, but I've only used them once recently so I can't personally speak to longevity. Partsgeek.com has a good price on both lines, you'll want to go with the caliper and bracket set that will come with new guide pins and boots.
Old Apr 20, 2013 | 06:45 AM
antichrist's Avatar
I've used both the Cardone Discovery and Defender calipers without any issues at all. Well, on one of the rear calipers the mounting hole was too small, but 5 min to put it in the drill press and drill it out and it's been fine. I also just installed a set on my F-250 and they are fine.
thehun
Mar 7, 2013 01:35 AM
FightOnUSC79
Nov 26, 2010 09:43 AM
allblackhse
Sep 5, 2009 06:28 PM
skikir
Feb 13, 2008 10:34 PM
