Bad ground in power control module
I have a 2000 Disco II with the 4.0 eng. Iv'e been getting code p01540 (bank 2 sensor 1) I replace 02 sensor and got same code. I brought it to my mechanic and he found that the problem was a bad ground inside the PCM. He tried soldering inside the PCM to fix the ground but couldn't fix it. I would like to know if there is anything I can do to fix the problem our do I have to replace the PCM. If I get a PCM with the same numbers will it still have to be programmed?
Mecevans
08-09-2015 02:30 PM
RROJ
07-24-2011 07:59 AM
kcirtap
09-26-2007 09:39 AM
18nBallin
Audio/Visual Electronics
09-16-2006 05:02 PM
