Bad ground in power control module
Old Dec 12, 2014 | 02:25 PM
aftermath431's Avatar
Default Bad ground in power control module
I have a 2000 Disco II with the 4.0 eng. Iv'e been getting code p01540 (bank 2 sensor 1) I replace 02 sensor and got same code. I brought it to my mechanic and he found that the problem was a bad ground inside the PCM. He tried soldering inside the PCM to fix the ground but couldn't fix it. I would like to know if there is anything I can do to fix the problem our do I have to replace the PCM. If I get a PCM with the same numbers will it still have to be programmed?
Mecevans
Aug 9, 2015 02:30 PM
RROJ
Jul 24, 2011 07:59 AM
lordmorpheus
Sep 5, 2010 05:43 PM
kcirtap
Sep 26, 2007 09:39 AM
18nBallin
Audio/Visual Electronics
Sep 16, 2006 05:02 PM
