Bad Head?
Old Aug 4, 2017 | 06:54 PM
CaptainAaron's Avatar
Default Bad Head?
Hello All,
I acquired an extra set of heads about one year ago. I had them refinished in case I ever needed a set. They have been on the 'spare parts shelf' since then. I pulled them off today and found a series of gashes. Can they still be used? Or do I need to find another head?
Old Aug 4, 2017 | 07:19 PM
LR03NJ's Avatar
As long as they are completely flat. the gasket will seal the sides.
Old Aug 4, 2017 | 07:20 PM
That is what I thought. They are completely flat otherwise.
Old Aug 4, 2017 | 07:59 PM
abran's Avatar
Bad Head? is there really such a thing? or just some better than others...
Old Aug 4, 2017 | 08:13 PM
Wow.... I really set myself up for that one
Old Aug 10, 2017 | 08:49 PM
usaf_disco's Avatar
how did you manage to gouge it like that???
Old Aug 11, 2017 | 10:02 AM
Not sure. Heads were stored inside a big plastic bin wrapped in plastic and towels. Only other thing I thought of was they could have been damaged on the ride home. Gouges are not deep and otherwise the head is flat.
Old Aug 11, 2017 | 11:54 AM
Same thing I was thinking....
Old Aug 11, 2017 | 01:26 PM
OffroadFrance's Avatar
And that applies to most makes and models not only LR's. Every alloy head on many makes and models seems to be a lottery whether it's good, bad or just indifferent.
Old Aug 11, 2017 | 01:29 PM
Don't worry too much, as long as they are flat and the gouges don't enter the gasket fire ring or cross the oil/waterways they should be OK.
