Bad hub?
Old Jun 18, 2011 | 05:24 PM
kenk's Avatar
Default Bad hub?
Is it possible for the hub/wheel bearing to go bad and not set off the 3-amigo's? I am getting a dull-thud noise, cosistent with road speed, that sounds an awful lot like a bad hub/wheel bearing. Also, no looseness in the either front wheels(where it sounds it is coming from). It gets worse under load than when coasting. Front d/s is brand-spanking new, but I am going to remove it and drive w/out it to see if it changes.
What ya'll think?
Old Jun 18, 2011 | 06:27 PM
Have you lube the drive shaft and was the centering ball replaced?
Lift the bad side and wiggle the tire from 12 and 6 position.
Old Jun 18, 2011 | 07:18 PM
Yes it is possible.
But try this first, swap your tires and see if the noise follows.
SO if it is coming from the right front swap it with the left front.
It sounds more like a stone stuck in the tire to me.
Old Jun 19, 2011 | 10:18 AM
RAYMAN975's Avatar
when my front left wheel hub/bearing went, it set of the dash lights, i had it reset, and it was another 2 or more months till the lights came back on from it, by then, it was in definite need of replacing, it was pretty clunky
TheWhiteRover
Aug 16, 2014 08:20 AM
starcraft1
Nov 13, 2011 08:14 PM
oljohnboy
Sep 14, 2009 03:01 PM
jycsalas
Oct 29, 2008 03:01 PM
Bene
ROAMING WITH FRIENDS
May 11, 2005 04:33 AM
