Bad master cylinder vs air in brake lines.
Old Mar 12, 2025 | 01:12 AM
evil_goat's Avatar
Question Bad master cylinder vs air in brake lines.
When braking it seems that my pedal goes down too much. It stops OK in normal conditions. If I pump the pedal twice it does not go down as far on the second press and seems to stop better. Without double pressing and going down a steep hill, I can get the pedal to bottom out and it sometimes does not fully stop the car. Pads and rotors seems to be in decent condition but are probably old. Could my symptoms be a result of old brake fluid with air, or do I have a problem with the master cylinder?
Old Mar 12, 2025 | 09:50 AM
H20nSnow's Avatar
"pumping up the brakes" is a classic indicator of air in the lines. Could it be the MC? Yep, could be how the air is getting in the lines. First step with a soft pedal is to properly, thoroughly bleed the system. Then monitor their condition. Does the problem come back or are you good now? If it comes back you have to start sleuthing. I had a car once where I never resolved the problem. I rebuilt all four calipers and the MC, no difference. An out of alignment rotor can suck air into the calipers, I worked that path to death and found nothing. Searched for pinholes in the lines, nothing. Good luck, I hope it was just a poor bleed in the past.
Old Mar 12, 2025 | 10:14 AM
ahab's Avatar
Check the RAVE for the bleed sequence. It's not the normal "start with the furthest away and work your way to the master".
Old Mar 12, 2025 | 03:23 PM
rikkd's Avatar
What does the fluid look like?
Old Mar 12, 2025 | 03:58 PM
Externet's Avatar
For air to get in the brake lines besides the obvious not-tight fittings, the fluid must be displaced somewhere else; either leak or calipers volume expansion.
The master cylinder reservoir had to go empty at a certain moment to suck air.
Old Mar 17, 2025 | 11:54 PM
evil_goat's Avatar
Fluid looks good. I think there is is a leak between the reservoir and the cylinder, so I'll just replace the entire assembly.
Old Mar 18, 2025 | 01:53 AM
AlWorms's Avatar
Check the wheel bearings for play.
Movement can move the pads apart, as the rotor moves sideto side, then it takes a pump or two to get them closer to the disc, then the final press actually acuates the brakes.
bradleyd
Jan 3, 2018 08:24 AM
romulus prime
Mar 3, 2016 08:40 PM
Mark Spohr
Jul 14, 2015 06:03 PM
mattyh007
Sep 22, 2009 09:56 PM
larry99discoI
Aug 22, 2007 02:35 PM
