Bad Oil Leak after changing Valve Pan Gasket
Old Aug 6, 2014 | 09:48 PM
Bahamarover's Avatar
8th Gear
No the oil light was not on. Just had this bad leak and smells like its over heating since the gasket repair. Using a lot of coolant and oil since repair a few weeks ago...I complained and some part was tightened says it was not tight and that oil should stop. It did not. I kept a close eye on the performance of the car and reduced my usage of it. This the fourth time bringing it back but the first time they really kept it and went back over it.
Old Aug 6, 2014 | 11:23 PM
Jared9220's Avatar
If the oil pressure switch was bad I would think that it would be triggering the red oil pressure light on the dash, so that makes me question that theory right off the bat. The only thing I can think is they might mean that the oil pressure gauge is broke and leaking I've never heard of that.
What part did they admit forgetting to tighten?
Did you show them how RTV needed to go on the valley pan gasket end seals?
If your rear main seal really is the problem it is going to be expensive to fix. I for sure would not let that shop do the work. If they can not handle a simple valley pan gasket then the rear main seal is out of the question.
You really should try and get your money back on the labor at least since they didn't fix a freaking thing.
Old Aug 6, 2014 | 11:34 PM
Dave03S's Avatar
And find a reputable independent Land Rover Specialty... ONLY shop.
Not a foreign or import car shop... Not your sisters boyfriend...
Not a Dealer either.
If you specify what area of the country you are in, maybe someone here can point you in a better direction.
A few minutes with your favorite search engine should help you narrow down a proper shop. Do your research, read reviews, go see what their shop really looks like in person and talk to a few different places and ask lots of questions. Take a look at what kind of vehicles are around and their general condition.
shezm
Jul 24, 2014 10:08 AM
mike111
Jun 2, 2014 08:58 AM
Phatrowles
Jan 9, 2014 10:36 AM
Pauli
Jan 19, 2009 06:56 PM
91rover
Jun 13, 2007 03:15 PM
