Bad tick in my '04
Old Jan 10, 2012 | 03:23 PM
toad2's Avatar
Default Bad tick in my '04
I removed the belt but it's still ticking. Has anyone ever had a tappet tick?
I'm going to remove one plug wire at a time and see if it stops. Any suggestions would be welcomed. Thanks
Old Jan 10, 2012 | 03:46 PM
creepin's Avatar
I have and 04 with a tick also..But it comes and goes...Has been for over 3yrs...Still runs strong...Personally I think something is sticking...
Old Jan 10, 2012 | 04:19 PM
toad2's Avatar
Forgot to say, the tick is only at idle. When the engine is revved, the noise goes away. Does this sound like valve train noise or bottom end noise?
Old Jan 10, 2012 | 04:23 PM
creepin's Avatar
I cant tell....See Thread on oil, just ck'd it out this may help us.
Old Jan 10, 2012 | 05:32 PM
If your oil pump looks like this, it can tick, and make enough PSI to turn off the light (7PSI), but not the 50 PSI that is spec for warm and 2000 rpm - test oil pressure with manual gauge.
Old Jan 10, 2012 | 06:07 PM
creepin's Avatar
But its not all the time that it ticks.....Sometimes it is a soft tick sometimes loud tick then it will just fad away all at idle....And like I said not at all.....Very strange...At least to me....
Now if it were a pump wouldnt it be all the time?
Old Jan 10, 2012 | 06:34 PM
boris_gti's Avatar
No it wouldn't tick all the time. Mine only did it under load and never when reving the engine. Sometimes I could hear it on the idle....sometimes I couldn't. Just like yours mine was outside of the cursed VIN range. However......sh1$ happens.
Strongly suggest to do the oil pressure test. If the pressure is good, then you are good to go. If it isn't, then it's a ticking time bomb that can cost you thousands of $$$$$$. It's not worth the risk.
Get your oil pressure checked.
Old Jan 10, 2012 | 07:17 PM
creepin's Avatar
I hate to say this but its been doing this for over 3 yrs....and 20k miles.....
On another thread someone had change to Rotella and it got cured?????
Old Jan 10, 2012 | 07:21 PM
creepin's Avatar
What was yours?
Old Jan 10, 2012 | 07:34 PM
Oil changes will not do anything but put a bandaid on a valve train noise. Been driving it for 3 years, you are running the old cash flow meter the longer you put of dealing with this issue.
