Bake Pedal leaks down and pumps up
2001 Discovery ll, panic stop will not lock brakes and does not engage ABS. Pedal sinks down and vehicle comes to a stop over an extended distance. The LR dealer changed the brake fluid and then bled the system with the computer technique and returned the vehicle with the same problem. If you pump on the brakes rapidly four or five times and then hit them hard, you can get a decent stop, but still not quite get the ABS to come on. Any help appreciated.
PPRussell
PPRussell
Becareful about just changing the brake master cylinder for this problem. First thing was to flush the brake system and activate the abs pump. Make sure all four wheels spin easily and are not binding from sticking calipers. Clamp off the brake lines from the master cylinder too see if the brake pedal still sinks, if still sinks brake master is worn out. If not abs pump may have stuck or worn valve inside of it. Many people have replace brake master cylinders for this problem including me, only to have it be the abs pump. ***Sometimes you have to replace the master cylinder anyway to confirm the abs pump is defective.
An update, they did the computer bleed, and you can now sort of get the ABS to engage if you really stand on them on pavement and at speeds over about 40MPH but the pedal is soft, not firm. If you put the passenger side wheels on dirt and leave the driver side on pavement and stand on them, the ABS definitely engages well and keeps you going straight.
I have two other large SUV's an older Mercedes and a V-10 Ford Excursion with the severe service brake upgrade in the front. On both of those, you can mash down on pavement and get the ABS typical shuddering and no spongy feel to anything. You get a good, firm pedal in those babies. This is our first Land Rover, maybe some more experienced owners here can tell me if the soft pedal on the Discovery ll is typical or do I need to push the dealer further to resolve it?
