Ball joint removal
Old Nov 13, 2007 | 08:09 AM
Newbie's Avatar
Default Ball joint removal
Hi everyone!
So while I was rebuilding the drivers side front hub and swivel assembly, I decided to repalce the ball joints as well. I got the ball joint out of the swivel arm using a ball joint separator tool from Atlantic British. Then I loosened the clamp on the rod. So far so good. But when I tried to unscrew the ball joint from the rod, I could barely get it to turn a few degrees in either direction. What am I doing wrong? Is there a special tool I need to unscrew these?
Thanks in advance for your help!
Andrew
Old Nov 13, 2007 | 08:31 AM
jkid's Avatar
Default RE: Ball joint removal
I would say a vice clamped on one end, large vice grips on the other end and the addition of heat if needed (not too much)would do the trick. Are you talking about the steernig tie-rod?
Old Nov 13, 2007 | 09:25 AM
Newbie's Avatar
Yeah it is the steering ball joint that attaches to the driver side swivel. The rod has the steering damper attached to it. I am kinda worried because I need to replace all 5 and I can't even get the first one off :-)
I will give that method a try!
Thanks
Andy
jrm123180
Mar 8, 2020 12:33 PM
Robover01
Jun 8, 2011 12:42 PM
Clunker
May 9, 2011 08:16 PM
jeff07ski
Nov 5, 2007 01:30 PM
pom1987
Apr 20, 2006 04:37 AM
