Barely audible pulsating/low freq beeping sound coming from ABS module
Anyone know why the ABS module would be making a barely audible pulsating beeping sound? No key in ignition and hood up when I heard the sound. No big deal, just curious.
I notice it will stop after a certain period of inactivity. I had mine parked for a week and the only time it made that sound was when I locked and unlocked the car and it would take a good while for it to stop...
ALL normal.
ALL normal.
Take it to the dealer and have it fixed for free.
this will run your battery dead.
It is not supposed to last any more than 5-10 mins after you shut the truck off and remove the key.
I hope this is normal. What is the recall and TSB?
A recall is a know defect that the manufacture is either forced to fix for free by the Fed's or take it upon themselves to fix for free.
A TSB, Technical Service Bulliten, is a know problem that they may or may not fix for free.
The 2003 oil pump issue is a TSB, for example.
If you go to www.edmunds.com you can look up recalls and TSB's for your car or truck.
Mecevans
Aug 9, 2015 02:30 PM
davidshawbass@gmail.com
Mar 5, 2010 11:05 PM
