Batt+oil+check engine ligh
Old Nov 14, 2016 | 09:11 AM
abran's Avatar
So is there a down side to removing the valve cover baffle?
In the name of science I elect Charlie to remove his, he has tried everything else...
Old Nov 14, 2016 | 09:33 AM
Charlie_V's Avatar
I humbly accept the nomination. But it may be awhile because I am shunning my rover right now.
Old Nov 14, 2016 | 09:50 AM
mln01's Avatar
Shunning your Rover is one thing but it's good you're not shunning us.
Old Nov 14, 2016 | 10:16 AM
abran's Avatar
Dont let your Rover know it's on purpose!
Old Nov 14, 2016 | 06:36 PM
Charlie_V's Avatar
Any time I even THINK it is a fine machine, running well, proudly carrying me... it ****s the bed. As long as I treat it with disdain, it runs like a Swiss watch.
Old Nov 14, 2016 | 09:00 PM
Des1480's Avatar
I was checking codes using harbor freight code reader and it stated " no pending or stored codes", not sure if a more sophisticated code reader could do a better job. I did recently, about a month ago, perform transmission service, diff service, and replaced ignition wires and plugs as per disco mike's specifications. Truck had been running great after that.
Old Nov 14, 2016 | 10:11 PM
abran's Avatar
you two need counseling, sounds like a textbook abusive relationship. Your rover has daddy issues.
Old Nov 14, 2016 | 11:44 PM
Charlie_V's Avatar
Any old code reader should show you the codes. And you didn't mention clearing them. And it still won't start? And there are no codes?! Amazing.
You mentioned replacing the wires. The Deputy's post #4 is right on the money for the big issues but I'm always looking for electronic gremlins. If you replaced the spark plug wires and had the coils out are you sure the coil packs', idle air control valve's and purge valve's connectors are in tight? Were you able to keep the metal retainers on them and get them pressed / snapped back together?
Have you pressed the inertial switch? (Black thing on passenger firewall... press down in round part). The inertial switch would cut the fuel. But it wouldn't make it run tough. That's an on or off deal. Similar issue could occur if the fuel pump relay or fuel pump failed.
And the final electronic gremlin I can think of... crank sensor. I'm drawing a blank on how to know whether that's the problem, but it won't start with a failing or failed one and the engine could run badly if the sensor was failing. People have had trouble with oil in the sensor and the connector. Maybe someone else can pitch in on that.
Without codes, I'm a little lost. So if checks of the items above don't bear fruit then The Deputy's list is complete for what makes an honest engine run. Or, check his list first... there is a guy on the forums who couldn't get his to start because his timing chain broke, which I thought was basically impossible. So anything is possible.
Old Nov 14, 2016 | 11:45 PM
Charlie_V's Avatar
Hahahaha! It is definitely abusive. I just have the upper hand at the moment... only because I can afford to buy new company and my rover can't do squat about it.
Old Nov 16, 2016 | 03:41 PM
Des1480's Avatar
Decided to try and start her up in between jobs and BAM she fired right up. No lights no nothing. Don't have time to test drive before work just encase I get stuck, but dam these cars! Luv to hate them! Thanks for the help everyone.
