Batt+oil+check engine ligh
Old Nov 16, 2016 | 05:36 PM
  #21
The Deputy's Avatar
Sure sounds like something electrical, if it fired right up. I'd certainly stay close to home and check the fuel pump circuitry snd crank sensor.
Brian.
Old Nov 20, 2016 | 03:12 PM
  #22
Des1480's Avatar
Well the problem persists! Starts up no prob some times and just cranks other times. Once it fires up runs great. Took it to advanced auto and machine couldn't read battery. Girl was nice but not overly helpful. Reader just told her to re-adjust the connections. Any thoughts???
Old Nov 24, 2016 | 10:21 AM
  #23
Des1480's Avatar
Default She's Back
New battery and she is running like a dream!
Old Nov 25, 2016 | 09:30 AM
  #24
Charlie_V's Avatar
Yay! That's good news.
Old Dec 5, 2016 | 07:22 PM
  #25
Des1480's Avatar
Well the problem persists. Saturday I started up drove about 15 mins between 30 - 45 mph. Parked car for about 4 hours, went out for lunch and it started right up. Drove around doing some errands suburban conditions. parked car for another 4 hours. went out to drive home and car would not start! Check engine and battery light stay on but car won't turn over. left car overnight and came back the next morning and it started right up. I am at a loss.
Old Dec 5, 2016 | 10:00 PM
  #26
Charlie_V's Avatar
Okay. Shot in the dark ... the new battery made it behave. You drove it a few days and the problem returned. Are your headlights nice and bright? Do you have any means to check your alternator? I know, I'm stuck on the battery, but it did seem to fix it and I've gotten stuck before, got a new battery, then had the same issues again several days later (when the battery went dead again).
I took my alternator to a shop and there was a broken wire somewhere in the copper.
Old Dec 8, 2016 | 07:33 PM
  #27
Des1480's Avatar
Replaced the CPS and hasn't not started, but driving home from shop got check engine with code P0130......truck is testing my patience!
Old Dec 8, 2016 | 08:22 PM
  #28
Luckyjayb's Avatar
Another question out of left field....have you recently swapped from air bags to coils in the rear? If so did you have it programmed and remove the proper fuses and relays. I know if you don't, it will drain the battery QUICK!!! First hand experience here
Old Dec 8, 2016 | 09:20 PM
  #29
Charlie_V's Avatar
Okay another shot in the dark. My battery kept dying over night and I found out that my new brake booster is a little shorter than the old one, meaning that the pedal doesn't reach the brake switch...
​​​​​​resulting in brake light being on continuously. For days.
EstorilM
Jan 20, 2016 06:40 AM
demonfork
Sep 9, 2013 03:06 PM
sclarkie
Aug 22, 2013 08:17 AM
rdd8014
Mar 6, 2013 07:56 PM
javoli002
Jul 16, 2009 01:24 PM
