Battery Light on, voltage dropping
Old Oct 21, 2017 | 08:20 AM
cybercop's Avatar
Default Battery Light on, voltage dropping
Battery light came on. Truck Died.
Jumped Truck, Truck Died.
Put new battery in truck.
Battery light still on.
Volt meter on battery shows voltage at battery at 14.15 but dropping. Now in the 13s
Bad Alternator??
Old Oct 21, 2017 | 08:57 AM
LR03NJ's Avatar
Bad Alternator??
YES! Bad alternator.
Old Oct 21, 2017 | 09:03 AM
aemnky606's Avatar
X2 on that alternator. Not sure on a d2 but the RPM's will jump like crazy on a d1 when the alternator is dieing. That is also a clue also that it's the alternator.
Old Oct 23, 2017 | 08:12 PM
cybercop's Avatar
Whats the brown and yellow wire for?
Old Oct 23, 2017 | 08:16 PM
LR03NJ's Avatar
If i remember, there are only 1 thick and 1 thinner wire if its the alternator and it can only be installed to the right size stud on the alternator.
Old Oct 23, 2017 | 08:44 PM
number9's Avatar
When the voltage applied to the alternator/generator side of the ignition/no charge warning
lamp exceeds the battery voltage applied to the warning lamp, the lamp is extinguished. This
shows that the alternator/generator is producing battery charging current.
Goes to alt light to turn it off when alt voltage higher than battery voltage.
Alt light will remain on if wire not attached.
Old Nov 2, 2017 | 12:07 AM
cybercop's Avatar
Replaced Alternator, All Good!
Idioteque2
Dec 17, 2015 05:44 AM
vonrock
Feb 12, 2015 08:16 AM
rimskych
Member Group And Special Buys
Sep 28, 2014 07:23 AM
rekogniz1
Oct 19, 2009 11:46 PM
