Battery Red Light
Old Mar 12, 2015 | 12:37 PM
xaviercampos's Avatar
Default Battery Red Light
My battery light on 2003 Discovery recently has been coming when I start up engine. However, it usually turns off after I rev up the engine to about 3500 rpm's.
So the light goes away as soon as I drive.
I took her to AZ (Autozone) to check the battery and the alternator and both are good. Or at least that is what they said.
Any Ideas...?
Old Mar 12, 2015 | 01:24 PM
Lowest Bidder's Avatar
Do you live in a cold environment, and how old is the battery?
I'm asking because I had a battery with a bad cell that tested fine when warm, but had low voltage when cold, around 0 deg. Celsius.
With the alternator running, even at idle unless the battery was really depleted, voltage should be around 14 volts. With a full charge, without the engine running, and with the battery unhooked, it should read at least 13 volts. A bad battery's voltage will drop significantly as soon as a load is applied, even a small load like the AC fan.
In cold climates like here, a car battery is expected to last around four years.
Also smart chargers are relatively inexpensive nowadays, and they have nice features such as desulfating and testing.
Old Mar 13, 2015 | 02:40 AM
I do. but it wasn't that cold...
Old Mar 13, 2015 | 06:04 AM
drowssap's Avatar
check the connection on the back of the alt. especially the smaller wire
Old Mar 13, 2015 | 11:14 AM
bballjames's Avatar
I'm going to throw my bet on the battery...
tornado_735
Mar 11, 2010 05:55 PM
Rover Kid
Member Group And Special Buys
Dec 4, 2008 06:52 PM
icoolyou
Dec 17, 2007 02:33 PM
sna77
Apr 5, 2007 07:12 PM
arrkerr
Dec 14, 2005 10:06 AM
