Red Service Engine light on D1...real quick...
Old Mar 11, 2010 | 12:09 PM
tornado_735's Avatar
Default Red Service Engine light on D1...real quick...
What problems does it light up for?
Old Mar 11, 2010 | 01:52 PM
britishracinggreen's Avatar
The red service engine light on a D1 is an emissions reminder that comes on at about 90k. in the right front kick panel there is a brown relay with a land rover sticker on it. I've read that this can be reset by sticking a length of straight metal (coat hanger) through the hole under the sticker. I had no such luck. You can either replace the relay (if you live in a state where they check emissions) or remove the relay altogether (if you don't live in a state where they check emissions).
Old Mar 11, 2010 | 01:55 PM
antichrist's Avatar
I think most states they don't care if it's on with an OBD1 car, which the '95 is.
Mine's been on for 3 or 4 years.
Old Mar 11, 2010 | 02:35 PM
ljdiscovery's Avatar
Thumbs up
It is very easy to reset the emissions light, well, at least it was for me.....There are a number of threads on the forum or check in the RAVE CD. Find the box as mentioned, peal back the sticker, use an awl or long piece of stiff wire or steel rod, anything will work and push the reset button. That should shut the light off. I had to mess around with mine for a few minutes til I was able to push the right spot and reset the system. The only difficult part was trying to climb into the passenger side footwell....Good Luck. Phil
1999 DI 103k miles
2001 DII 80k miles
Old Mar 11, 2010 | 05:55 PM
okdiscoguy's Avatar
Pull the cover off the relay. It comes off easy enough. Got this from D-web:
LeakyDisco
Oct 25, 2012 01:38 AM
felipenaves
Mar 19, 2012 10:48 AM
kcferna
Jul 7, 2009 08:33 AM
mr_boondoggle
Freelander
Jan 2, 2009 09:32 AM
97LANDISCOVERY
Aug 19, 2007 04:10 PM
