Battery Shut-Off Switch
Get a digital multimeter (they can be had for $5). Unhook the neg. battery cable and put the meter "in-line" between the battery cable and battery post using the probes. Then see how much current is being drawn on your meter. Then start pulling fuses until the amps drop. I'm not sure about a Disco, but most cars normally have about a 40 mA drain so don't be surprised if it doesn't drop to 0.
I am doing the whole 60k service thing so I'm sure I will be back and forth on these forums asking questions as I am no expert mechanic, but I can get by. I am more familiar with small engines and things that have a carburetor.
Went to change the fuel filter today, and holy crap, talk about seized....I'm going to have to get new rubber lines, because only one of the ends would come out of the filter, the other one wasn't even close to coming out. Looks like it hasn't been changed in a long time, and the ****ty gas that came out of there was unbelievable. Not to mention the lines themselves don't look that great....Will probably change those too, but I'll save that problem for another post, along with getting the diff lock to work again. haha, lots of work to be had on these disco's. I'm up for the challenge!
Cheers, and thanks for the help guys.
By the way, what setting should I have the multimeter on to check the fuses?
AB, and probably others, sells a kit to replace the rubber lines at the filter. But considering it's a standard Delco/Wix/Fram filter, you should be able to get what you need at the local NAPA. Cut back the metal line to where it's smooth, couple of compression -> hose barb fittings with a swivel fitting to fit the filter at the other ends and you're good to go.
haverhillguy
Feb 11, 2010 08:24 AM
