Bearing Clearance
The min-max 0.00004" difference is not much less tight in my book. I found no other official specs after doing several web searches and found them to be similar for the original Buick 225. Recommended clearances seem to be unusually small compared to typical for some reason(?) and that's what our QC guy wants to check for. As No Doubt said once checked and final assembly done, "Either the crank turns or..."
All the relevant spec clearances are contained in the RAVE, General Info, pages 04-03 to 04-05 inclu: However, this is for a 4.0L engine but the clearances should be exactly the same for a 4.6L. Contained in RAVE is all the torque settings also on other pages.
Where did you find the a lot less tight clearance spec for the LR V8? We would like to see them.
FYI there is a separate engine overhaul manual that is pretty key for doing this sort of stuff. Attached. This is the 4th edition, which took me awhile to find -- most search results out there are all for the 3rd edition.
Just saved an offline copy, thanks Jeff
Main bearings
Main bearing diametrical clearance . . . . . . . . . . . . . . 0.010 to 0.048 mm 0.0004 to 0.002 in
Oversizes . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.254, 0.508 mm 0.01, 0.02 in
Big-end bearings
Big-end bearing diametrical clearance . . . . . . . . . . . 0.015 to 0.055 mm 0.0006 to 0.0021 in
End-float on journal . . . . . . . . . . . . . . . . . . . . . . . . . . 0.15 to 0.36 mm 0.006 to 0.01 in
Big-end bearings
4th edition is in the Range Rover section of Rave for those that have the whole enchilada.
Same specs made it into the General Data section of the RR Workshop Manual as well.
Specs in the Defender section even more generous.
Having 2 factory service manuals contradict one another builds confidence doesnt it.
The .002 seems more realistic.
I'll mic the crank journals, and use a bore gage in the main and rod bearings, and hope for the best.
Be the weekend before I get to it.
I'll post pics, and my results.
If you have the time and inclination a few photos of the bore gauge in use may be helpful for others in the future. Thanks.
