BECM
Old Feb 21, 2007 | 05:19 PM
havhon's Avatar
3rd Gear
Default BECM
Where can I get my BECM repaired for a decent price. I am having a problem with my rear running lights not coming on and I have no dash lights. I haven't troubleshot this problem to the BECM, but I am almost certain that this is the problem.Britrish Pacific claims that theses parts are no longer available and the only way to deal with the problem is to find a used part or have your repaired. Thanks.
Old Feb 21, 2007 | 05:29 PM
okdiscoguy's Avatar
Default RE: BECM
moron question, but you are sure you checked all of the fuses, right? Had the same prob, but found 1 little 10 amper out right by the SRS fuse. be careful...
Old Feb 21, 2007 | 07:51 PM
havhon's Avatar
3rd Gear
Default RE: BECM
ORIGINAL: okdiscoguy
What was so moronic about my question (ya - I checked the fuses)?? It really amazes me how many jerks there are out there. Thanks for the help moron.
Old Feb 21, 2007 | 08:01 PM
okdiscoguy's Avatar
Default RE: BECM
I think you mis-understood me. I was saying that Isounded a moron for asking. I was not calling you a moron. I checked all of my fuses, but I missed one. It was the one that took care of the problem.
I was the moron. Sorry you took it the wrong way.
Also, here is a used one from roverlandparts.com
http://www.roverlandparts.com/index....p;Category=394
Old Feb 21, 2007 | 11:44 PM
havhon's Avatar
3rd Gear
Default RE: BECM
discoguy,
Sorry about the reply - I owe you an apology. Aftersome research, I found out that I should replace the fuse box in the engine compartment that feeds the BECM before I replace the BECM. Rover reccomends the replacement of this box every five years. The problem with these boxes is corrosion. The corrosion then leads to shorts - opens - etc. They also say that if you are having ANY type of elec. problem - replace this box first before troubleshooting a problem to the BECM. Also, a bad fuse box will cause a diagnostic to show BECM failure. This could lead to an unneccesary replacement of a BECM.
94mattda
Mar 26, 2009 06:34 AM
phill5409
Sep 24, 2008 05:38 PM
climberbruno
Jun 15, 2008 08:52 PM
2000rrhse
May 30, 2007 04:37 AM
Richard1
Nov 30, 2005 04:40 PM
