1997 BecM failer
Old Sep 5, 2008 | 02:26 PM
phill5409's Avatar
6th Gear
Default 1997 BecM failer
[:@]My 1997 range rover 4.0 will start but cant get it out of park.it shows fuse 6,7,17 fault and gearbox fault,i checked all the fuses and the break switch,and there are all ok.I suspect my becm,can i get the becm repaired and reprogrammed or do i have to buy a new becm?,will unlocking the becm help? Please help
Old Sep 5, 2008 | 03:54 PM
Default RE: 1997 BecM failer
Long shot. Do your brake lights work? If not this will be a bad brake switch, which many other Rovers also experience.
Old Sep 5, 2008 | 04:31 PM
phill5409's Avatar
6th Gear
My brake lights are out and a/c control panel lights are out too.there is no power going to the switch from the becm.when i put a jamp to the brake switch all lights come on and am able to shift but the vehicle will not engage,it will stays in neutral and i can not drive
Old Sep 5, 2008 | 10:39 PM
roverguy7's Avatar
it sounds like a BeCM, you might want to check underhood fuses, all of them, and also the connectors at the BeCM, make sure all the pins look clean and tight. and no, it sounds more like a circuit failure then a software issue, reprograming it probably wont help, i know there are companies out there that do this, never had any expierence with them though
Old Sep 24, 2008 | 05:38 PM
ptschram's Avatar
Start with cleaning the fusebox first. You arelikely gonna find that the voltage to the BeCM is low on the forward terminal lug.
94mattda
Mar 26, 2009 06:34 AM
climberbruno
Jun 15, 2008 08:52 PM
2000rrhse
May 30, 2007 04:37 AM
havhon
Feb 21, 2007 11:44 PM
Richard1
Nov 30, 2005 04:40 PM
