Bedliner for wheel flares?
Has anyone used bedliner on their wheel flares? I need to do mine again. I used black paint years ago and that has deteriorated. I am thinking bedliner, because they will not be smooth anyway, and covering that with UV resistant clear coat.
I have bedliner on mine, had them prepped (while on rover), sprayed and that was 4 years ago. Paid $100 for the four flares plus the rear door latch above the license plate. If they ever dull, I throw a coat of armour all on them and they shine right up.
+1 for the PlastiDip. I sprayed it on the vehicle and then scored around and peeled it off the body. I found the thicker it's applied the easier it is to peel off the body.
Mine has probably been sitting on there for about a year now.
I had this done when I lived in Houston, it's actually sprayed on, took them about an hour with prep.
If you go the bed liner route and want to DIY, stay away from the spray cans. I tried several and they do not spray very clean or cover near as good as the liquid rolled on from the gallon or quart. I did my headliner and my nudge bar with the stuff and turned out excellent. The pro guys spray with the right equipment not the rattle cans.
