belt noise when start engine in the morning?
Old 07-26-2007 | 11:32 AM
mimimi's Avatar
Default belt noise when start engine in the morning?
when we start our 2003 Disco in the early morning, it has a high-pitched sound from front, then disappears, does not come back when driving.
is it some kind of belt noise? is there a serpentine belt in this car? our car is 78000km(around 50000mile)
Old 07-26-2007 | 11:45 AM
SpeedAgent's Avatar
Default RE: belt noise when start engine in the morning?
Could bea belt tensioner or a pulley, or just a squeaky belt. If you can determine where it is coming from, other than "the front"you can further diagnose exactly what the problem part is.
Old 07-26-2007 | 12:08 PM
jdelp's Avatar
How new are you to your truck? Did it just start? If it's truly a squealing, then as mentioned it could be tensioner or idler pulley possibly. But, when I first got my truck I had it looked at b/c there was a mild "squeal" that then goes away which turned out to be the secondary air pump - normal operation. It's fairly mild, so there's a difference between that and a belt squeal. I'd pop your hood w/ the engine cold, fire it up and see where it's coming from.
Old 07-26-2007 | 01:22 PM
mimimi's Avatar
thanks, there was a shop just done the alternator belt several days ago(before the used car dealer sold car to us), i will check with the shop
Old 07-26-2007 | 01:26 PM
Find out if they replaced the serpentine belt, also the belt tensioner and idler pulleys all of which can be involved in making your noise.
Mike
CANAMDiscovery
10-10-2012 08:42 AM
98disco
02-03-2009 08:55 AM
shark19
10-05-2008 08:33 PM
alamosweets
09-28-2007 09:46 AM
Quick Reply: belt noise when start engine in the morning?
