Best coil packs?
Old Apr 3, 2017 | 01:51 AM
NickAdams's Avatar
Default Best coil packs?
There are plenty of threads about using Bosch O2 sensors, but a search revealed no opinions about the best coil packs. They are a long ways in there, and I might as well use the best while replacing them. Opinions? Experience?
Old Apr 3, 2017 | 07:48 AM
Best4x4's Avatar
The best type of coil pack = one that works lol.
I've used non Bosch coil packs for years on D2's with no issues.
Old Apr 3, 2017 | 09:10 AM
JUKE179r's Avatar
I bought Standard Motor Products' #UF-545 on Amazon $41.33 since they come with both coils.
I haven't installed them yet but people on the forum stated to use your old mount bracket. Apparently the new bracket that comes with coils doesn't fit correctly.
Old Apr 3, 2017 | 05:07 PM
LR03NJ's Avatar
Thats a good point regarding the correct fitment on the bracket. I found out when doing a coil project getting few different packs. Its true its not direct fit that is why i had to off set the measurement to fit different packs. Thanks
Old Sep 8, 2022 | 09:19 AM
Toms's Avatar
What brand of coils do you recommend? I have a slight fault in minimum new spark plugs I have not put the cables yet but I wanted to take advantage and change the coils since it is not so friendly to remove them
Old Sep 9, 2022 | 08:17 AM
NVDiscovery's Avatar
I used Bosch and non-Bosch coil packs. Recently installed a new pair of Bosch as I find the quality (construction/materials/weight) better but to each his own. Overall, I'm headed back to more Bosch parts to eliminate compatibility issues.
Old Sep 9, 2022 | 08:20 AM
Toms's Avatar
If I have read here that the standard brand coil packs and that they are excellent, now I see some Bosch on the internet that do not have the yellow sticker and others have nothing
Old Sep 9, 2022 | 08:24 AM
I bought my coil packs (no mounting bracket) from Rock Auto.
Old Sep 9, 2022 | 08:28 AM
Toms's Avatar
I'm seeing some on Amazon in 53 without base and the pair in lucky in 78 without base I'm going to check rock auto thanks
Old Sep 9, 2022 | 02:30 PM
zski128's Avatar
OE Bosch on RockAuto for $36 each.
