There are plenty of threads about using Bosch O2 sensors, but a search revealed no opinions about the best coil packs. They are a long ways in there, and I might as well use the best while replacing them. Opinions? Experience?
I bought Standard Motor Products' #UF-545 on Amazon $41.33 since they come with both coils.
I haven't installed them yet but people on the forum stated to use your old mount bracket. Apparently the new bracket that comes with coils doesn't fit correctly.
Thats a good point regarding the correct fitment on the bracket. I found out when doing a coil project getting few different packs. Its true its not direct fit that is why i had to off set the measurement to fit different packs. Thanks
I've used non Bosch coil packs for years on D2's with no issues.
What brand of coils do you recommend? I have a slight fault in minimum new spark plugs I have not put the cables yet but I wanted to take advantage and change the coils since it is not so friendly to remove them
I used Bosch and non-Bosch coil packs. Recently installed a new pair of Bosch as I find the quality (construction/materials/weight) better but to each his own. Overall, I'm headed back to more Bosch parts to eliminate compatibility issues.
If I have read here that the standard brand coil packs and that they are excellent, now I see some Bosch on the internet that do not have the yellow sticker and others have nothing
