Best Diagnostic Tool For D2 but support others too
Subscribe
Mar 13, 2022 | 03:25 PM
I am looking for a Diagnostic tool to upgrade from my old basic OBD II (INNOVA)
I see the functionality of the LR only or specific models like Nanocom, but I don't mind spending more for a unit that will do all the things for our D2's but also more in depth for other cars.
Needs:
  • Detailed Codes for D2 - including ABS codes "Three Amigos"
    • including Power Bleed, etc.
  • Support for other LR models (Maybe LR4 & older Defenders)
  • More detailed info on other makes I have - Ford especially
Reply 0
Mar 14, 2022 | 11:01 AM
I guess I'll be the tester for this one. I went with the Foxwell NT809, mostly because it will work with all the cars I need, and will do most of what I need for the '04 D2 I have.
Reply 0
Mar 15, 2022 | 07:14 PM
Interested to hear how this works on your D2. I was looking at the Autel diag tools, like the AP200. Support was a little vague on what live data I could see.
Reply 0
Mar 16, 2022 | 06:52 PM
The best is nanocom but I've been using the Autel AL619 and it works fine to read/clear codes...it also does show some live data which was helpful in troubleshooting my o2 sensors.
Reply 0
Mar 16, 2022 | 09:13 PM
If you want cheap with lots of compatability torque pro $6 bucks and a $20 ELM blue tooth obd dondle. Will read o2 voltages, coolant temp, map, read/cear cels. Won't do abs. Works with Android, I don't know about ios.
Reply 0
Mar 17, 2022 | 06:06 AM
Quote: The best is nanocom but I've been using the Autel AL619 and it works fine to read/clear codes...it also does show some live data which was helpful in troubleshooting my o2 sensors.
the Foxwell the op got is a bidirectional diag tool. Does the Autel you have live data for misfires, voltages for the evap system components, etc?
Basically this list:
https://www.nanocom-diagnostics.com/uploads/downloads/Bosch%20Motronic%20M5.2.1%20EMS%20ECU%20Guide.pdf
Reply 0
Mar 17, 2022 | 12:08 PM
Bidirectional is one of the reasons I went with the Foxwell NT809. When it arrives Friday I plan on doing a lot of playing around with it. I'll report back but if there is something you would like to see, I'm happy to check it out.
Reply 0
Mar 21, 2022 | 07:05 PM
So I got the tool and so far I'm underwhelmed. I wasn't expecting a perfect LR specific Nanocom and needed a tool for multiple brands of cars, but I am having a hell of a time getting it to connect to the D2; especially the ecu for the abs module. I know it's connecting to the ABS system because it illuminates the ABS Light, Traction Control HD, etc while it is trying to communicate.
  • So far I am unable to read the ABS codes.
  • It doesn't auto recognize the vin
  • It doesn't recognize the VIN with manual entry
  • It Does see the vin on the Engine ECU module
I will reserve full judgement for when I hear back from tech support.
Reply 0
Subscribe
