Best engine gaskets
Old Apr 8, 2013 | 11:14 PM
Barat11's Avatar
8th Gear
Default Best engine gaskets
I am looking to replace my oil pan gasket on my 2000 DII. Is a gasket a gasket or is there a recommended brand?
Thanks
Old Apr 8, 2013 | 11:15 PM
ZGPhoto's Avatar
They'll all fail eventually, you'd be better off doing a great job getting the heads machined and torquing down the bolts correctly than getting a better gasket.
Old Apr 9, 2013 | 07:08 AM
drowssap's Avatar
well I don't see why "you'd be better off doing a great job getting the heads machined and torqueing down the bolts correctly than getting a better gasket." if you changing your oil pan gasket, but what do I know.
Get any brand name gasket and put a very thin coat of black RTV on both sides (very thin) then torque it in place it. That's how I did mine over 2-years ago and it does not leak a drop and has never required tightening. JMHO
Old Apr 9, 2013 | 07:34 AM
People have also used Permatex Right Stuff gasket maker. But while you are in there, consider cleaning off the oil pickup screen, and replacing the O-ring or seal for that pickup tube, and a dab of loctite on the two bolts that hold it in place.
ZGphoto must have been out again with that 600 mm lens pointed at the spring break gals on the beach oggling his Disco, just a little fogged up this morning....
Old Apr 9, 2013 | 08:21 AM
ZGPhoto's Avatar
Bahha...was thinking of head gaskets, not oil pan!
Old Apr 9, 2013 | 05:07 PM
Barat11's Avatar
8th Gear
Thanks for the gasket assistance. Savannah thanks for addressing the cleaning of the pickup screen. I was going to ask if any additional items should be addressed while the pan is off.
Thanks again,
Old Apr 9, 2013 | 05:15 PM
aarongregor's Avatar
ZG I was also thinking HG, when I read that drowssap put RTV on it I was like no way!
Old Apr 9, 2013 | 05:35 PM
wreckdiver1321's Avatar
Hey man reading is difficult.
Old Apr 9, 2013 | 08:23 PM
jfall's Avatar
Victor Reinz
Old Apr 9, 2013 | 09:13 PM
MuddMouth's Avatar
Whatever gasket you decide on, I recommend YamaBond ... Yamaha's very own gasket sealer/maker... the shiz is great I use it on everything.
