Best gas?
Tried a bunch of em. Truck likes Exxon premium the best for pep and mileage. Aware that gas is mostly the same, only additives different. But there is a difference, and that's what works best.
If you run non premium (87) octane your knock sensors will retard your engine and it will seem normal, but it isn't... you're just used to it running retarded. It takes more than one tank of premium to reset the adaptive values to run on the proper gas.
See the pics in this thread, this is what cheap gas does... https://landroverforums.com/forum/di...se-help-90193/
Gas here is not the same.
You didn't notice because the engine is controlled by a computer programmed to make sure you don't notice the effects of lower than optimum fuel. It's a design feature programmed into the ECU to allow the vehicle to operate in various conditions. The ECU is programmed for optimum performance and efficiency using 92 octane premium as stated in the owners manual and at the fill location.
Compensating for low quality fuel comes at a cost. Those costs are well documented in general but specific to the LR V8 lower octane fuel burns hotter. Generally we are all trying to get these trucks to run cooler. Less efficiency. Lower MPG, More heat. Lose Lose Lose. Oh yeah, and sludge from lack of detergent or just a sooty burn like when you get the gas mix wrong when OXY welding.
Go cheap if you want but accept the consequences knowingly.
