Best & Most Complete Head Gasket Kit
i don't know whether they are factory, but turner engineering uses them so that's good enough for me.
It's the aluminum heads on aluminum block and overall design with the use of stretch bolts. If it were that simple, a better head gasket would have been designed long ago.
I have only heard one other forum member(besides you)state that Fel Pro are the best, but have never used them. I have spoken to professional engine builders who recommend Elring, so I have used those exclusively since.
I don't think it's the gaskets fault for failing at 75-100k. Do you think Fel Pro gaskets will allow you to do 200k miles without an HG job?
I have read many a post where the 2nd and even 3rd round of cyl head gaskets have failed on somebody's Disco; which brand of gaskets were used is of importance but the factory bolts used in conjunction is probably a deal breaker regardless. I can't imagine replacing the cylinder head gaskets more than once on the same vehicle. Obviously you are aware that I had the VR cyl gaskets but the other times I had FelPro for intake manifolds and valve covers for other maintenance items & I was impressed with their product after using various other name brand manufacturers.
The first 2 jobs I did, I used Victor Reinz. Since then I have used Elring.
The second one I did has the most mileage that I am aware of @68k with stretch bolts.
I have yet to have a job fail prematurely. If people are eating up head gaskets, there is something else going on.
Addressing the original poster: you will get 100s of opinions/ suggestions. Personally, I had 1 ongoing chat with Jason & another 1 with Abran to discuss all of my head gasket replacement questions & concerns as I went along. I would recommend contacting 1 of these experienced members so that you aren't overwhelmed with so much varying and/or conflicting feedback such as with posting openly on forums; it's just something to consider & Abran is particularly knowledgeable
Thank you very much for all the information!
I apologize for the delay on getting back, but I have been very ill lately.
So apparently based on normal consensus we should go with the Lucky 8 kit and ARP studs.
Now the million dollar question is labor cost. I never done a HG in my life, so not sure how realistic is to try it, in your opinion is it twice as complicated as the full tune up and the removal of the intake manifold?
Or should we just take somewhere? or may be there is a member around Tampa that will like to do it?
now wondering about the price range...
Engine Refresh (top end) | PaulP38A.com
It does take some dedication but there is so much info on the repair plastered all over the web that anybody who sets out to do it will be able to dig up enough resources to make a good repair. I picked a couple of guys that I trust & had ongoing text with them to get through it with minimal issues. There is just so much detail involved that you can't afford to make any mistakes if it's a daily driver.
Maa45069 (03-10-2017)
This video will give you an idea of the involvement.
https://m.youtube.com/watch?v=Zwdg1XCsI_w
